Standard interface and master control adaptation schedule
Knowledge
Introduction
How to Make Sure That the Robot Controller Supports Standard Interface Communication?
How to Configure IP Address and Port Number in Robot Communication Configuration?
Why Set Host IP Address to 0.0.0.0 When Vision System Acts as Server?
A general introduction to IP address and port of TCP/UDP server
Introduction to Mech-Mind Vision's Communication via Profinet and Ethernet/IP
Operational practices
- Explanation of Common Mech-Center Logs
- Reduce project cycle time on the robot side
- Add standard interface calibration for the new robot brand and set the corresponding Euler angle convention
Guide for implementing standard interface programs in the background
Troubleshooting
How to Troubleshoot Failed Standard Interface Communications?
IPC
Standard interface
- Troubleshooting Steps for Standard Interface Failures to Trigger Mech-Viz or Mech-Vision
- Why the poses from the standard interface and Mech-Vision are differernt
- Solution for error “Number of points exceeding index”
- Result of Mech-Center Standard Interface 210 Command Planning: Anomalous Z-value in TCP Pose for Robots like FANUC
Errors
- Status Codes and Troubleshooting
- OSError: [WinError 10013] An attempt was made to access a socket in a way forbidden by its access permissions
- OSError: [WinError 10038] An Operation Was Attempted on Something That Is Not a Socket
- Rokae: Standard interface robot end error: Number of strings obtained by the strSplit function does not match the predefined string length.”
- KUKA Error 2135 Name not declared as subprogram
