What does the temperature drift of a 3D camera refer to? What are the main factors affecting temperature drift?
1. What is Thermal Drift?
Thermal drift in a depth camera refers to the phenomenon of overall depth value drift as the temperature changes.
2. Main Factors Influencing Thermal Drift:
Temperature changes are primarily influenced by two factors: the impact of spontaneous heating during camera startup and the influence of environmental temperature changes.
3. Effects of Thermal Drift:
Since thermal drift is characterized by an overall drift in the camera’s Z-axis in its coordinate system, it generally has minimal impact on most grasping projects. However, projects that are sensitive to changes in Z-values may be moderately affected.
4. How to Reduce the Impact of Thermal Drift:
Control changes in camera temperature, such as using a thermal unit.
Avoid solutions involving “top-view imaging” or “side assembly.”
Additionally, this Q&A post may be helpful: Temperature drift - Q&A - Mech-Mind Online Community
