Model compatibility
This Mech-Eye Industrial 3D Camera cable selection guide if applicable to the following camera models:
- UHP-140
- NANO
- NANO ULTRA
- PRO XS
- PRO S/M
- LSR S/L/XL
- LOG S/M
- DEEP
Ethernet cable
Mech-Mind provides straight and 90° elbow-shaped aviation plug Ethernet cables used on cameras. Please choose the appropriate length of the cable based on your usage needs.
For specific parameters, please refer to: Ethernet Cable Datasheet
Power cables
Mech-Mind provides two power supply options: 24V DC power supply and power adapter. It is recommended to use the 24V DC power supply option in industrial settings.
A. 24V DC power supply (recommended)
Mech-Mind offers straight and 90° elbow-shaped aviation plug DC power cables used on cameras. Please choose the appropriate length of the power cable based on your usage needs.
For specific parameters, please refer to: DC Power Cable Datasheet
Please choose a 24V DIN rail power supply with a capacity of not less than 90W. You can contact Mech-Mind to purchase the DIN rail power supply, or use another DIN rail power supply that meets the corresponding safety standards.
Recommended models:
- Global (excluding India): Meanwell NDR-120-24 (Certification: UL/CE/CB/EAC/UKCA/RCM/RoHS)
- India: Meanwell EDR-120-24 (Certification: UL/CE/CB/EAC/UKCA/RCM/BIS/BSMI/RoHS)
B. Power adapter option
In addition to the 24V DC power supply option, Mech-Mind also provides a power adapter option, which includes a 24V power adapter and an AC power cable. The AC power cable is available in five options: Chinese standard, American standard, European standard, British standard, and Japanese standard. For specific selection, please refer to: AC power cables (with adapter)
Material code
Ethernet cable
| Length | Material code(straight) | Spec(straight) | Material code(right-angle) | Spec(right-angle) |
| 5m | 01292510 | CBL-ETH-5M | 01292518 | CBL-ETH-5M-LU |
| 10m | 01292511 | CBL-ETH-10M | 01292519 | CBL-ETH-10M-LU |
| 15m | 01292512 | CBL-ETH-15M | 01292520 | CBL-ETH-15M-LU |
| 20m | 01292513 | CBL-ETH-20M | 01292521 | CBL-ETH-20M-LU |
| 30m | 01292514 | CBL-ETH-30M | 01292522 | CBL-ETH-30M-LU |
DC power cables (can be used on DIN rail power supply)
| 5m | 01292493 | CBL-PWR-5M | 01292502 | CBL-PWR-5M-LU |
| 10m | 01292494 | CBL-PWR-10M | 01292503 | CBL-PWR-10M-LU |
| 15m | 01292495 | CBL-PWR-15M | 01292504 | CBL-PWR-15M-LU |
| 20m | 01292496 | CBL-PWR-20M | 01292505 | CBL-PWR-20M-LU |
| 30m | 01292497 | CBL-PWR-30M | 01292506 | CBL-PWR-30M-LU |
| Material code | Spec | Comment |
| 02022001 | NDR-120-24 | Global (except India) |
| 01062007 | EDR-120-24 | India only |
