Connection table for camera power supply port and ETH port
The power supply interface for Mech-Eye Industrial 3D Cameras is an M12 4-pin A-coded aviation plug, while the network interface is an M12 8-pin A-coded aviation plug.
Power supply port connection table:
ETH port connection table:
- When connecting an aviation plug, please pay attention to its direction. After the connection is made, it is recommended to secure the cables with ties.
- Regarding power supply, it is recommended to use a 24V isolated adapter or a 24V isolated rail power supply.
- When using long power cables, it is important to ensure that the output voltage is 24V.
Features of power supply cable and Ethernet cable
| Power supply cable | Name | Purpose | Feature |
| External cables (standard rail power supply solution) | M12 4-core drag chain power cable (with magnetic ring, without line card) | For rail power supply Worldwide compatible |
Drag chain cable: dragging cycles ≥ 8 million times; torsion cycles ≥ 3 million times (180°). The shielded layer is grounded and M12 plug pins are made of environmentally friendly 3u gold-plated brass. |
| External cables (adapter) | Standard drag chain; 220V AC power cable | For rail power supply Worldwide compatible |
Drag chain cable: dragging cycles ≥ 8 million times; torsion cycles ≥ 3 million times (180°) Standard three-pin male and female connectors. |
| Ethernet cable | Name | Purpose | Feature |
| External cables (standard network cable) | M12 to RJ45 drag chain network cable | For rail power supply Worldwide compatible |
Drag chain cable: dragging cycles ≥ 8 million times; torsion cycles ≥ 3 million times (180°) The shielded layer is grounded; RJ45 head must have a shielding layer and RJ45 inner core is 3u gold-plated. |
