For instance, when handling symmetrical workpieces using the teaching method to minimize the issues of tangling hoses and cycle time caused by the six-axis robot rotation, it is necessary to fix the robot’s orientation for gripping. However, when a fixed orientation is set within the Mech-Vision project, grip accuracy becomes a concern.
To simultaneously ensure accuracy and fixed grip direction, you can utilize the “geocenter” of the workpiece. After “3D Coarse Matching,” correct the gripping point’s orientation, then utilize “3D Fine Matching” to ensure precision. Subsequently, map the “geocenter point” to the “teaching pickpoint”.
