Calibration mainly involves the intrinsic and extrinsic parameter sets. The extrinsic parameter set is calculated and its corresponding situations are as follows:
It is basically sufficient. For the “segment_params”, “layer_ini_depth”, “layer_interval”, and “region_size” in the extrinsic parameters, you can supplement them based on actual data. The specific meanings of each parameter are as follows:
“segment_params”: the image size of the depth map.
“layer_ini_depth”: the position of #Layer0 in the camera’s field of view.
“layer_interval”: the distance between adjacent layers.
“region_size”: the size of each planar region.
