When open Mech-Center and Mech-Vision at the same time, the Mech-Vision project will take more time than normal or stuck at some step.
However, when just open Mech-Vision and run the same project, the time cost is normal.
- What is the solution for this problem?
- What is the reason for such a problem?
Reason:
The compatibility property configuration for Mech-Center and Mech-Vision will cause such problem.
If the Software running at compatibility model, it will call other dll files which are related to compatibility model to slow down software running.
Solution:
Please make sure Mech-Vision is not running at compatible mode.
The configuration instructions are as shown below:
If the running time problem still exists after unchecking the compatibility mode options, please contact Mech-Mind stuff for remote checking.
