Our customer uses our UHP-140 cameras but does not employ our software. Instead, they process images using Halcon. Currently, they require intrinsic parameter files in JSON format for the camera.
However, the sample we currently provide only displays intrinsic parameters and cannot save them in JSON format. Can we provide an additional sample to help the customer achieve this?
After the steps above, you can obtain the JSON file in the folder where the Halcon program is located. The JSON file obtained from the sample above is as follows: {"DepthMatrix":[1276.4987987901245,0,1,1,793.3323974609375,784.47187042236328]}
You can modify the content according to your specific needs.
AI BOT
Mech-Mind AI Assistant
Hi, I am your AI assistant
Picking Solution Support
