How should the power supply for the linear guide be correctly wired, and where should the ground wire be connected?
The correct wiring for the linear guide power supply is as follows: Please note that the grounding should be done by connecting the PE wire to the designated grounding location below. The +V and -V on the output side should not be grounded.
For instance, when using Omron’s linear guide power supply, grounding the -V (0V) terminal can result in both PE and 0V being grounded. This can potentially lead to reverse current flow if there is a leakage in the circuit, causing a surge in current and potentially damaging the equipment.
