I do not have a 3D model of the object, but I want to create a template by stitching together the point cloud of the actual object. Do we have any tools to accomplish this?
If the software does not have similar tools available, are there any other software recommendations?
We do not have any relevant tools available. We suggest capturing the same object from different angles and obtaining multiple point clouds. Then, you can use the “point cloud registration” feature in CloudCompare to merge them together. Finally, make slight adjustments as needed.
AI BOT
Mech-Mind AI Assistant
Hi, I am your AI assistant
Picking Solution Support
