This video series will guide you to get started with using the Mech-Mind Vision System. After watching this series, you will be able to use the vision system to capture images of workpieces and guide the robot to pick and place them.
 Part 1: Vision System Hardware Setup Part 1: Vision System Hardware Setup
 After watching this video, you will know how to install a camera and IPC and establish communication between the two hardware. This process ensures efficient and effective image capturing.Click the link to view the accompanying tutorial document.
 Part 2: Robot Interface Configuration Part 2: Robot Interface Configuration
 This video shows how to establish communication between the Mech-Mind Vision System and the robot, enabling the vision system to guide the robot’s motion.Click the link to view the accompanying tutorial document.
 Part 3: Hand-Eye Calibration (Master-Control) Part 3: Hand-Eye Calibration (Master-Control)
 In this video, you will learn how to perform hand-eye calibration to obtain the transformation between the camera and the robot reference frames. This transformation aids the robot in accurately locating objects based on the camera’s perspective.Click the link to view the accompanying tutorial document.
 Part 4: Workpiece Locating Part 4: Workpiece Locating
 In this video, you will learn how to readily utilize a pre-built solution from Mech-Vision’s solution library to locate workpieces. The objective of workpiece locating is to guide the robot in picking them up accurately.Click the link to view the accompanying tutorial document.
 Part 5: Perform Picking Part 5: Perform Picking
 In this video, you will be guided through editing a Mech-Viz project’s workflow to plan a collision-free path for the robot to pick and place.Click the link to view the accompanying tutorial document. The version of software used in the video collection: V1.7.x.
More videos are coming soon…
