Say if we have two work stations next to each other, is it possible to have one camera mounted to a rail or conveyor belt and have it move between two stations without compromising the accuracy?
This approach is feasible, but it could potentially impact grasp accuracy, as the camera’s exact positioning cannot be guaranteed with absolute precision after every movement. Therefore, if you have stringent accuracy requirements, we do not recommend adopting this approach. If you still wish to proceed with this solution, it’s advisable to use a servo motor-controlled slider with a positioning accuracy of ≤0.1mm and regularly check the positioning accuracy to maintain precision.
