I tried to download the calibration software on mechmind website but met with an error code while installing it
Troubleshooting Procedure
Please refer to the following procedure: Installation Guide
Obtain a new installer and check its integrity, then try the installation again.
- If the issue is resolved, the troubleshooting is completed.
- Otherwise, proceed to step 2.
Find the folder “{180DA015-BC2A-4262-928A-D312B20D9977}v7.40.4997.501” under the directory “C:\ProgramData\Package Cache”.
- Otherwise, proceed to step 3.
Right-click the installer and select “Run as administrator” to reinstall.
- Otherwise, proceed to step 4.
Try the installation again after the other Wizard finishes installation or after the Windows system upgrade completes.
- Otherwise, proceed to step 5.
Restart your IPC or computer and try the installation again.
If the problem still exists, click the “installation log” link in the Finish window to collect installation logs and send them to Technical Support.
