After the testing, we realized that we misplaced the bracket for the LSR L. Is it possible to use the bracket meant for the PRO S to install the LSR L?
If both the PRO S and LSR L are V4 models, the brackets should be identical and interchangeable.
LSR L(V4), DEEP(V4), Log M(V4), PRO S/M(V4), UHP-140 all share the same bracket.
For more information, please refer to the camera, bracket, and FOV model available at Downloads—Camera materials. There, you can access the bracket model and a PDF with its dimensions.
