[Work with new ABB CRB 1910 and Robotware 8
Symptoms
  • System can not run autocalib on ABB CRB 1910 , can not move correctly
  • Somethings running on Robotware 8 robot can trigger robot to run
Root Cause
  • The formal version of Viz is not compatible for CRB1910, and robot .morb file parser can not parse the robot .morb correctly.
  • Robotware 8 has a write permission system.
Fix
  • Replace the robot morb parser with file below in Vision installation dir
    mmind_robot_algo.dll (7.0 MB)
  • Relplace robot file (or add new) with file below
    abb_crb_1810_10_1_52.mrob (1001.0 KB)
    it shows 1810, but 1910 is enssentially the same thing, when select robot , chosse 1810.
  • If still can not use the robot, contact MM tech support
  • Release the robot write permisiion on teach pendant (Robotware 8 feature) when execute programme.
