Online Robot Library Brand Change: FR → Fairino
Compatibility Matrix
Project Type Software Version Required Action Status
Existing project using FR robot model 2.1.2 and earlier Continue using without any changes :white_check_mark: OK
Existing project using FR robot model 2.2.0 and later Re-select the specific Fairino robot model from the online library :warning: Action Required
New project using Fairino robot model 2.1.2 and earlier Not supported. Communication errors will occur :x: Incompatible
New project using Fairino robot model 2.2.0 and later Works normally :white_check_mark: OK
Frequently Asked Questions
Q1: After upgrading the software, can existing projects still use the FR robot model?
You need to reselect the robot model from the online library.
After upgrading to version 2.2.0 or later, search for Fairino in the robot library and select the corresponding robot model according to the actual robot being used.
Q2: What should I do if a new project uses the new Fairino robot model from the library, but the software version on site is still 2.1.2?
You need to upgrade the software.
The controller and standard interface in version 2.1.2 and earlier do not support the Fairino brand, which will trigger the following error:
Error Code: 3004
Error Message: Unsupported Euler Angle Type
Solution: Upgrade the software to version 2.2.0 or later.
