Hi I am using the Mecheye Nano ultra-gl connected to a linux computer running ubuntu 20.04. I have installed your SDK v2.5.4. I am able to see the camera using the IP configure tool in ubuntu and I can choose the camera index 0 when I run the sample ConnectToCamera project on Github but I get a segfault and an error message that the camera failed to connect to the Ethernet port of the computer. I have pasted the full error message when I run the program at the end of this message. I also get a segfault when I am using the ip_configurator tool trying to change the IP address on ubuntu. I have to connect the camera to a windows computer to change the IP address for testing.
Steps so far I have done to debug this issue:
- Confirmed that my machines Ip address is on the same subnet as the camera for the Ethernet port the camera is connected to. I can ping the camera via the ping tool in the terminal. Camera IP: 192.168.1.101 Subnet mask: 255.255.255.0, Ethernet IP: 192.168.1.100 Subnet mask: 255.255.255.0.
- Tried another very different set of IP addresses Camera IP: 169.254.4.29 Subnet mask: 255.255.255.0, Ethernet IP: 169.254.4.44 Subnet mask: 255.255.255.0.
- Tired downgrading to SDK v2.5.1 but that segfaults in a lot of the programs because I think the FW on my mecheye does not support that SDK. I have not found a way to also downgrade the FW yet so this may still be something we can try if I can get the FW to match the older SDK?
- I have connected the mecheye camera to a windows computer and I am able to connect to the camera in the Mech-Eye Viewer software and take pictures.
- I have confirmed that the MTU size is correct and I have not enabled large packets on the ethernet.
- I have disabled all other network interfaces and disabled any VPNs on my machine. During this I am still able to ping the cameras IPaddress.
twoeste@3460db4:~/projects/mecheye_cpp_samples/area_scan_3d_camera/Basic/ConnectToCamera/build$ ./ConnectToCamera
Discovering all available cameras...
Camera index: 0
Model: Mech-Eye NANO ULTRA-GL
Device name:
Serial number: RUM35254A510EG20
IP address: 192.168.1.101
IP address assignment method: Static
Hardware version: V5.2.0
Firmware version: V2.5.4
Support status: Supported
Please enter the index of the camera that you want to connect: 0
Failed to obtain the IP address of the computer Ethernet port connected to the device. Please try disabling the Ethernet interface cards not connected to the device.
ping: option requires an argument -- 'I'
Usage
ping [options] <destination>
Options:
<destination> dns name or ip address
-a use audible ping
-A use adaptive ping
-B sticky source address
-c <count> stop after <count> replies
-D print timestamps
-d use SO_DEBUG socket option
-f flood ping
-h print help and exit
-I <interface> either interface name or address
-i <interval> seconds between sending each packet
-L suppress loopback of multicast packets
-l <preload> send <preload> number of packages while waiting replies
-m <mark> tag the packets going out
-M <pmtud opt> define mtu discovery, can be one of <do|dont|want>
-n no dns name resolution
-O report outstanding replies
-p <pattern> contents of padding byte
-q quiet output
-Q <tclass> use quality of service <tclass> bits
-s <size> use <size> as number of data bytes to be sent
-S <size> use <size> as SO_SNDBUF socket option value
-t <ttl> define time to live
-U print user-to-user latency
-v verbose output
-V print version and exit
-w <deadline> reply wait <deadline> in seconds
-W <timeout> time to wait for response
IPv4 options:
-4 use IPv4
-b allow pinging broadcast
-R record route
-T <timestamp> define timestamp, can be one of <tsonly|tsandaddr|tsprespec>
IPv6 options:
-6 use IPv6
-F <flowlabel> define flow label, default is random
-N <nodeinfo opt> use icmp6 node info query, try <help> as argument
For more details see ping(8).
Connected to the camera successfully.
Disconnected from the camera successfully.
Segmentation fault (core dumped)
Thank you for any support in this issue!
