Zigzag pattern on a matched object
How can I create a zigzag pattern to the objects I matched on a point cloud.
My point is like this and I matched this object.
What I am trying to do is create a zigzag pattern around this object with some offset around it. The “Generate Zigzag Path Around It” step acceps only 1D output.
I use mechvision 2.1 and Pro S camera
Thanks in advance
Hi @tekinal,
Apologies for the delayed reply.
For generating a zigzag path around a matched 3D object, the built-in zigzag path Step expects a 1D profile input. Here are some suggestions:
  1. Extract the object surface first: After matching, use Steps to extract the surface boundary or contour as a profile that the zigzag Step can accept.
  2. Custom Script Step: Programmatically generate zigzag waypoints based on the matched object pose and bounding box for full control over offset, spacing, and pattern.
  3. Path Planning in Mech-Viz: Depending on your application (dispensing, welding, etc.), Mech-Viz may offer more flexible path planning options.
Could you share more about your application? This will help us recommend the best approach.
Hi! I noticed your question has received a reply. Has your issue been resolved?
  • If resolved, please click the “Solution” button below the reply to mark it — this helps others with similar issues :pray:
  • If not yet resolved, please share an update and we’ll continue to follow up.
