Hi,
We are currently working on a project using Mech-Vision version 2.1.0, integrating the trigger and result query through the Standard Interface, with Mech-Vision acting as the TCP Server. Our camera model is Mech-Eye PRO S.
To retrieve the results, we are using the “Get Results Custom” command and have configured the corresponding Step Output with the Port Type set to Custom. Our goal is to increase the number of decimal places in the output values.
We noticed that under the communication settings, there is an Advanced Settings section with a Property Configuration tab. Is it possible to configure the decimal precision there?
We also found that using the Adapter Generator, it is possible to set the number of decimal places, but in that case, we are unable to use the Custom output format, which is required for our application.
Could you please advise how to increase the decimal precision in this scenario?
Thanks in advance!
Regards, Túlio
