When configuring a 3D Object Recognition step in Mech-Vision 2.0.0, it prompts you to select one or more objects to be recognized, but I can not figure out how to select any more than 1 at a time. I’ve tried holding ctrl and shift while selecting, but I just get a pop-up to save or discard the currently selected part.
3D Object Recognition does not support the simultaneous recognition of multiple workpieces in a single step. If you need to recognize multiple workpieces simultaneously, you can use the ‘3D Matching and Classification (Multiple Models)’ step or use multiple ‘3D Object Recognition’ steps in parallel.
Need to check the “Show all steps” for the Step Library, and ‘3D Matching and Classification (Multiple Models)’ step is under the “Advanced Step” group.
