When to use the virtual camera?
- When you want to use Mech-Eye Viewer but do not have a real camera to connect, you can use the virtual camera to gain familiarity with the software.
- When you want to load previously saved virtual data (file in MRAW format) and view the imaging effects, you can use the virtual camera.
How to use the virtual camera?
In the menu bar, under File, select Load Virtual Device File, and select the virtual device file saved in MRAW format.
Alternatively, you can connect to the sample camera built into Mech-Eye Viewer.
