Hi,
There is a solution I am trying to study but there is one step from the library which is the Extract 3D Points in Cuboid and this step has 5 parameters.
Thank you very much in advance.
Technologies:
- Mech-Vision version 1.6.1
Hi,
Technologies:
You can use the “Edit Procedure Parameters” function to “extract” the step parameters to procedure parameters.
https://docs.mech-mind.net/1.6/en-GB/SoftwareSuite/MechVision/CommonProcedures/ModifyParameters/ModifyParameters.html
