Problem
As shown in the figure, when the LNX laser profiler is triggered using an encoder, the Y-axis resolution parameter acquired from the Mech-Eye API matches the trigger interval, but differs from the Y-axis resolution parameter in the Mech-Eye Viewer software.
Explanation
The situation described above is normal, and the explanation is as follows:
- Mech-Eye Viewer: For both encoder trigger and fixed-rate trigger, the Y-axis resolution set in the Mech-Eye Viewer software is used as the distance between two spots, which is for convenient display in the Mech-Eye Viewer software.
- Mech-Eye API: For fixed-rate trigger, the Y-axis resolution acquired from the Mech-Eye API is the Y-axis resolution value set in the Mech-Eye Viewer. However, for encoder trigger, the Y-axis resolution acquired from the Mech-Eye API indicates the actual distance between two lines triggered by the encoder.
- In other words, when the Mech-Eye API is triggered by an encoder, the value of the Y-axis resolution acquired from the Mech-Eye API is unrelated to the Y-axis resolution set in the Mech-Eye Viewer.
