Mech-Viz 1.8.2
In the new Mech-Viz version how can you realize these two cases when you have mutiple Tools?
E.g. a two finger gripper with two or more opening widths for picking at different positions:
Opening width of 200 mm for label 0 (=tool 0) and opening width of 100 mm for label 1 (=tool1)
Mech-Vision returns a pose list (pose_0, pose_1, …, pose_N) and a corresponding label (label_0, label_1, …, label_N). Label 0 is used for indicating that tool0 is used for this pick point, label 1 for tool1.
Case:
The poses should be tried in the order that is coming from Mech-Vision independent of the label.
E.g. label = [0,1,1]. If pose_0 not pickable with tool0 then try to pick pose_1 with tool1 etc.
Case:
The poses of label 0 have priority and should be picked first. Only if none of the poses with label 0 can be picked, then the poses with label 1 should be picked. Vision moves have the “Use Specific Workobject Pose Only” enabled for the respective label/workobject.
Can this be achieved it with the example workflows that are shown above?
