What is the frames per second of the “Start Scanning” option in MechEye Viewer? If a user intend to have real-time, continuous scanning similar to a video and have rate of ~30 - 60 fps, can the setting be adjusted in MechEye software or MechEye SDK?
The frames you mentioned correspond to the 3D exposure time parameter of our camera. If you need higher frames per second, you can reduce the value of the exposure time. Conversely, if you need lower frames per second, increase the value of the exposure time.
