When using the bin feature for the scene objects, can the thinkness of the bin be added only in one direction instead of both?
If you add a bin by selecting a Scene model as Bin, sorry the thickness will be added in both directions.
Instead, you can construct the bin by adding each face of it (should be the type “cuboid”), then you can change the thickness of each face seperately.
Futhermore, if you want to change the bin pose integrally, you can set one face to be the parent node(by adding other faces as child nodes to the parent face).
