Problem
Mech-Center cannot be opened. When using the command line to open Mech-Center, Python reports an error: DDL load failed: The specified procedure could not be found.
Solution
- Uninstall the software and reinstall it.
- Download the repair tool “DirectX Repair” and use it for plugin repair.
- Check system environment variables. If there are environment variables similar to PYTHONHOME or PYTHONPATH, try deleting them. (Make sure that deleting the identified Python environment variables won’t affect other software.)
- If the issue persists, please contact Mech-Mind engineering support.
