I would like to know why does the ROI not adjust to a new ROI after being defined in Mech Eye.
Below is the target ROI:
Below is the result of depth map still using the default ROI:
FYI this was via Mech Eye Version: 2.1.0
It is because of the Capture Mode you used.
For Mech-Eye 2.1.0, the ROI is only effective when the Camera 1 mode is selected, and is ineffective when the Merge mode is selected.
This information is also outlined in our documentation, please refer to Capture Mode.
