Using the following namespaces:
using Emgu.CV;
using Emgu.CV.CvEnum;
using Emgu.CV.Structure;
using mmind.apiSharp;
How to Convert ColorMap Obtained from deviceCaptureColorMap() to C# Bitmap
You can use the following method to convert it to Bitmap format and save it. (Please add the code for connecting and disconnecting the camera as needed.)
How to Access Each Value Column-wise with ColorMap.Data() Instead of ColorMap.At().
The mentioned method utilizes IntPtr Data(), and in the API, not only does it provide IntPtr Data() but also Resize(uint width, uint height), allowing for corresponding access based on row and column indices.
