“Check Pose Repeatability by Statistics” needs repetitively run the project for static workpieces, how to run Mech-Vision project automatically without manually?
If you require the project to run at regular intervals, you can use the “period trigger” step.
If you want use control flow to run the project, you can use “trigger” step.
