Hello,
CodeSys-based PLCs (Wago, Festo, Lenze, some Schneider PLCs, some Eaton, Beckhoff) have some popularity in Germany & Europe. Are they supported / going to be supported for communication with Mech-Mind System?
Hello,
CodeSys is used to develop PLC systems, and CodeSys-based PLCs are a type of PLC developed by some PLC brands.
Whether a PLC of a certain brand or a model can communicate with Mech-Mind Software Suite depends on what communication protocols the PLC supports, such as TCP Socket, Modbus TCP, Profinet, EtherNet/IP, etc.
If the PLC supports any of the protocols mentioned above, it is possible for the PLC to communicate with Mech-Mind Software Suite through Standard Interface or Adapter.
Please refer to the following user manual links for more information:
