For SDK projects, when customers test the point cloud effect and accuracy, will enabling point cloud smoothing have an impact on the testing accuracy?
Hello, the surface smoothing function will result in the loss of some object surface details. The higher the level of surface smoothing, the more object surface details will be lost.
Therefore, if you require high accuracy in point cloud reconstruction, it is not recommended to enable excessively high surface smoothing parameters.
