When using the standard interface of a Fanuc robot and running mminitskt, it shows a successful connection but immediately disconnects
  • Software version (Mech-Vision 1.7.4, Mech-Viz 1.7.4, Mech-Eye Viewer2.1.0)
  • Camera model and firmware version:PRO S/2.1.0
  • Robot model:Faunc
Question:
I have already burned the program into the robot, when I run the mm_init_skt program, and it showed a successful connection but immediately disconnected. Is this a normal phenomenon?
This is normal. You only need to call this program once. The program contains both the connection and disconnection instructions, so it disconnects immediately after a successful connection.
