Analysis principles of measuring projects:
Workpieces have tolerances, generally requiring visual accuracy of 1/10 to 1/5 of the tolerance zone. For example, when producing a workpiece with a length of 50mm, a tolerance of ±0.5mm is considered acceptable. Therefore, the accuracy/error requirement for the visual system is 0.1mm = ±0.05mm. -
Accuracy analysis of the inspection system
(1) Comprehensive accuracy
Determine whether the system needs to be integrated with a robot, such as position detection. If so, the robot error should be added to the vision system error. Note: This is not a simple additive relationship.
The LNX laser profiler needs to be triggered in conjunction with the encoder of the linear motion mechanism, so its Y-axis accuracy will be affected by the encoder’s accuracy.
(2) Vision system
The accuracy of the vision system consists of hardware accuracy and software/algorithm accuracy . In practical projects, the software algorithm accuracy can be ignored and considered equal to the camera’s intrinsic accuracy. For example, for UHP, the accuracy is within 30μm.
