For using the deep learning model to recognize before the subsequent matching, I have attempted the following operations, but failed to pass the label. How should I resolve this?
How to pass the label recognized by the DL model to 3D?
Not sure if it’s exactly applicable to your scenario but I have encountered one scenario where I had problems with directly mapping labels from deep learning to model matching. Thought it’s worth a share.
Scenario:
Picked object:
Single rectangular object shape but comes in different colours. (Red, blue, yellow)
Plan of approach:
Workaround solution:
Note: Make sure that ‘Continue Given No Output’ is ticked for 3D fine matching and remove overlapped objects steps especially if you’re merging your data together later. (image 4) Otherwise, mech-vision will stop processing further steps if certain labels/colours are missing.
Hello Rene, thank you so much for sharing the solution in such great detail! It is a very clever strategy to map the labels from DL to 3D matching. I have tried your approach, and it works just fine now.
