I’ve already set a timeout limit of 60 seconds in Mech-Center, but I still receive a timeout error after sending 205. Why is this happening? Everything works fine when using the master control.
If there are loops within Mech-Viz, using the standard interface can generate an excessive amount of data, leading to errors. Although capturing images in advance during master-control can be used, when using the standard interface, Mech-Viz will continue running, and it’s uncertain when it will end and send all planned waypoints.
Therefore, you can try using the standard workflow without capturing images in advance, avoid using loops internally, and trigger the Mech-Viz project in advance using a robot or PLC to achieve the same result.
