Mech-Vision version: 1.7.1
I need to trigger and run multiple vision projects simultaneously.
Currently, using TCP/IP communication, when triggering multiple projects simultaneously, only after the previous project completes its processing, can the others be triggered to run.
Simultaneously triggering multiple vision projects is currently not supported.
- If you are using standard-interface communication, you can use “mm_start_vis” to start multiple projects one by one and then receive the visual processing results corresponding to each project.
- If you are using Adapter communication, since it involves custom communication code development, it is possible to achieve simultaneous triggering of multiple projects by implementing multi-threading within the Adapter. This programming task can be quite complex; if you have a project requiring this functionality, please contact MechMind technical support.
Are there programming examples for triggering multiple projects simultaneously?
multi_thread_adapter.py (3.7 KB)
The file provided is an external Adapter file.
If you are developing a common Adapter, you can copy and rewrite the “async_get_vision_callback” and “get_async_data” functions from the file. Then, use “async_call_vision_run” in the places where you need to trigger projects
