Software version:
- Mech-DLK 2.3.0
- Mech-Vision 1.7.1
Application background description:
Application is typical picking scenario for standard metal parts. However, due to the slip sheet between each layer and the metal attached to each other closely, instance segmentation based on deep learning is necessary to improve the vision project robustness. The responsibility for DL model is to distinguish the metal parts and slip sheet and to segment the metal parts.
Problem:
After training and verification, the DL model could segment the parts correctly. However, when the DL model implement in Mech-Vision, the result confidence value is not satisfied. Moreover, the edge of segmentation result is not guaranteed.
Question:
- What will cause such problems?
- How to figure out the reason? Any instructions for solving such problems?
