Mech-Vision Version: 1.7.2
DL Model: Box Super Model (CPU), I downloaded the DL Model form the community site.
When importing the DL Model, pop-up window shows the error as follows:
During the process of downloading file, the file could be corruptted. You can first use the CRC32 Code to verify if the file is damaged. If the CRC32 Code does not match, please attempt to redownload the file.
If 1st apporarch does not work, you cloud check the DL logs, deleting the files in the TEMP folder, and then reimporting the model package.
