There are two ways to integrate the Mech-Mind Vision System into other complicated systems:
Robots communicate with the Mech-Mind Vision system through a standard interface.
Robots are fully controlled by Mech Viz.
What is the difference between these approaches? What are the advantages of each? How can I determine which way is the correct choice for my application?
A standard interface maps commonly used functions into a set of standard commands. To integrate these functions with your robot, you only need to prepare a communication program on the robot’s side and load it onto the robot.
In the fully controlled model, the Mech-Mind Vision System acts as the master device, sending commands, while the robot serves as the slave device, executing tasks based on the commands it receives from the master device.
