UR robot, standard interface, the visual end only sends placement points.
Why is there a difference in the movement between the two positions simulated in Viz and the movement written in the robot program (different J5 poses)?
Here are two troubleshooting approaches for this issue:
- Confirm if the simulated positions in Viz are consistent with the robot program positions (JPs).
- Verify if the movement method of the positions in Viz matches that on the robot side (MoveJ/MoveL).
