Under normal circumstances, the Pick Anything Project generates a Mech-DL folder within the project directory, which contains the deep learning files. The Mech-DL files can only be used effectively on the same industrial control computer (IPC). In other words, if you change the IPC, the project may encounter errors.
Yes, normally, we changed the IPC. The Mech-DL file doesn’t work. In other words, we 'd better use the same Mech-DL files in same IPC.
